governor problem - Different
keddano
07-07-2005 21:24:11
Researched all the past postings on governor,dealing with a problem I've lived with on my puller as long as I've had it for the past few years,Too low of rpm's(looking for around 2000).Got around it by zip-tying the spring,etc.Just rebuild the lower end,and went thru the Governor (new bearing & thrust washer,spring)everything now seems good.Problem is even with new spring(18 active coils),full throttle speed is 1200 RPM,with all the threads tighten on the throttle to gov.flat bar and carb to gov. screwed all the way in.(as per manual and all advice on here),Doing some testing,with only 10 active springs,it'll get to about 1650 before the coil holder bottoms on the bracket with the spring way out. Right now all I can think of as a fix is too find a heavier spring,lighten weights,or thread rod farther and wait to over stretch spring.Is there something else in play here that I'm missing.Thanks in advance for taking time to read this,and any help.
