Rear tire options for Oliver 80 RC
Paul G. in Mn
07-05-2005 17:33:29
I have an oliver 80 row crop that had the 40 inch cast style wheels. I have the cast centers but everything else is gone. It would cost a small fortune to set this back up with 40 inch tires. I have been thinking about trying to find some 42 inch rims and use a larger clamp. Has anyone tryed this or have any better idea's on what i could use? Right now it has 38 tires and rims clamped on with a band dual style clamp. It works but doesnt look very nice. Thanks for any idea's Paul
old
07-06-2005 08:37:24
 Re: Rear tire options for Oliver 80 RC in reply to Paul G. in Mn, 07-05-2005 17:33:29
If it where me I'd get a differant set of center that where made for the 38 rims. I my area 38s are easy to find but 42s there hard to find and cost big $$$
Paul G. in Mn
07-06-2005 13:22:34
 Re: Rear tire options for Oliver 80 RC in reply to old, 07-06-2005 08:37:24
Might you happen to know what 38" centers would fit on an 80?
old
07-06-2005 14:16:53
 Re: Rear tire options for Oliver 80 RC in reply to Paul G. in Mn, 07-06-2005 13:22:34
Not off hand I don't. Do they have the 9 bolt centers? Or you might find hubs and U bolts from something like a 77
Paul G. in Mn
07-06-2005 14:55:38
 Re: Rear tire options for Oliver 80 RC in reply to old, 07-06-2005 14:16:53
no, they would I beleive a 10 sline axle. They use a wedge type hub.
Danny Tabor
07-07-2005 11:28:38
 Re: Rear tire options for Oliver 80 RC in reply to Paul G. in Mn, 07-06-2005 14:55:38
I've been told that some of the JD B's had the same size and spline axle as the Oliver 80's. I haven't been able to confirm that.
For my 80 I filled in the splines, grooved a single spline in the axles and used 88 hubs. Quite a bit of work but certainly better than leaving the tractor on blocks.
