I need help with 550 PTO
Jrry
07-05-2005 05:59:45
I took the top plate off the tractor to get to the pto clutch. (This plate also covers the regular clutch). The fork is not connecting with the pto clutch. I want to take the pto clutch out but there is the regular clutch bearing tube (looks like a cone) in my way. Am I doing this wrong? Will I have to split the tractor to get it out? I've adjusted the pto clutch from below the tractor but that was not the problem. How can I get the pto clutch to align with the fork? thanks in advance for any help.
James Alexander
07-06-2005 05:26:00
 Re: I need help with 550 PTO in reply to Jrry, 07-05-2005 05:59:45
If the PTO actuating fork is not engaged with the release collar, you have a problem. Do a "Z" split per the manual. Easy and requires much less disassembly. A little over an hour. This will give you good access to the PTO clutch hub after you remove the engine clutch release fork&shaft. Also remove the PTO actuating fork&shaft. At this point you should have access to whatever has come adrift or broken.
Jrry
07-06-2005 06:02:34
 Re: I need help with 550 PTO in reply to James Alexander, 07-06-2005 05:26:00
thanks James. I guess I need to get a shop manual. I have a parts manual but that dosn't help much. I think I'm at the point you refer to but can't figure how to get the engine clutch release fork & shaft out. Jerry
jake3x
07-07-2005 07:50:00
 Re: I need help with 550 PTO in reply to Jrry, 07-06-2005 06:02:34
You can't get thr shaft out it's still engaged in the clutch disc. You are making more work for your self by taking the the top off. In a z slit the front slides off and the PTO and the throwout bearing and housing can be removed and the entire PTO exposed, repaired. The Z slit makes it easy to reassemble, the clutch splines are lined up and slides together.
