660 rear end oil
meagain
07-04-2005 14:17:29
How much does it hold? Where do I check the level? Thanks.
ejr-IA
07-04-2005 20:29:25
 Re: 660 rear end oil in reply to meagain, 07-04-2005 14:17:29
Wrong place for transmission fluid that plug is for the pto fluid.You need to look futher forward near the gear shift lever their is another flat cap plug on top right of transmission.Check plug should be below this on the side of the trans houseing.
meagain
07-04-2005 16:56:49
I think I found it, but is that where you fill it too? How much oil do you put in the plug that's in front of/under the seat?
