OC3 Hydraulic Pump belt slipping
ChrisL
07-04-2005 12:11:15
Blade will not go up, I had noticed the pump was not turning at the same rate as the crank pulley, in other words; the belt is slipping, so I tighten the belt so that it is pretty tight, and still is slipping - - when trying to raise the blade the pump just about stops turning � I am guessing that the pump is at fault, any suggestions would help since the manual does not address the pump.
hector gemme
07-04-2005 15:08:23
 Re: OC3 Hydraulic Pump belt slipping in reply to ChrisL, 07-04-2005 12:11:15
HI The hydrolique pump work whit shaft bolte on crankshaft pully ,the probleme should be the shaft adaptor and Ihave some oc3 parts.
RAB
07-04-2005 14:25:40
Could it be the belt is worn out. If the belt is bottoming in the groove, no amount of tghtenining will make it more than a narrow flat belt.
Regards, RAB
ChrisL
07-04-2005 14:38:02
 Re: OC3 Hydraulic Pump belt slipping in reply to RAB, 07-04-2005 14:25:40
Good point - it"s one of those belt you can add or remove a link - I wonder if it"s not right for this application
Don-Wi
07-04-2005 20:19:09
 Re: OC3 Hydraulic Pump belt slipping in reply to ChrisL, 07-04-2005 14:38:02
I havn't heard much good about those belts period. They are great for an emergency, but not for any long-time use. Get yourself the proper belt before you try to trouble shoot it any more.
Donovan from Wisconsin
