oliver 550 hydraulic lift noise
oliver dave
07-01-2005 20:02:57
Why would the hydralic lift on my 550 make alot of noise?When I first got the tractor the lift had water in it. I pumped it the way the manual said,changed it with straight 30-40W motor oil like the manual said.The strange thing is, it only makes alot of noise when it is cold,after I work the tractor for about half a hour it almost stops making noise.
J. Schwiebert
07-02-2005 03:07:05
 Re: oliver 550 hydraulic lift noise in reply to oliver dave, 07-01-2005 20:02:57
Check 2 things first. If it does this when cold the pump can be caviating. Second thing you did not say what you are doing with the tractor but does your 3 point have any free travel when it is all the way up. Check it quick like by lowering the 3 point a couple of inches. If the noise goes away then you need to adjust your 3 point. Did you change the filter? Have you checked for water again because if you pumped the oil out you did not get it all. Also I thought the corect oil was 10W-30 which is an S# type engine oil. Does your tractor have an external valve.
oliver dave
07-02-2005 07:41:32
 Re: oliver 550 hydraulic lift noise in reply to J. Schwiebert, 07-02-2005 03:07:05
I think I know what your talking about,when its all the way up it sits there making noise untill you let it down a little.My tractor does not do that, it makes this noise when I lift somthing from any level like a bushhog or a hay bale somthing with some weight.No I didn't change the filter because it looked good and clean.I checked for water and the oil was not white.Your right,the right oil is 10-30W and that is what I used.And I don't have a remote valve on it.Somthing I just got to thinking about, is after you run it and you check the oil on the stick it has little bubbles in the oil.Do you think its getting air in the system?That would make that noise wouldn't it?
J. Schwiebert
07-02-2005 09:20:51
 Re: oliver 550 hydraulic lift noise in reply to oliver dave, 07-02-2005 07:41:32
Yes it would. Areation noise and caviataion noise is similar. I am going to bust your bubble a little bit. The human eye can see particles as small as 40 micron. You need to filter down to 30 micron, 10 for applications using a piston pump so I also joke with this question. How do you know your filter is doing a good job if it is to take out particles so small you can not see them.. Also did you change the breather on the hydraulic? Send me some information on how I can talk to you face to face or via e-mail. Right now you have perked my interest. Have a safe and sane fourth. J.
oliver dave
07-02-2005 11:24:48
 Re: oliver 550 hydraulic lift noise in reply to J. Schwiebert, 07-02-2005 09:20:51
Yes your right about the filter but where can I get one.I don't know of any agco around here I would need to find a phone# and have them send it.I checked the breather and it looked good but if it,s like a filter I had better change it to.A big problem that I just found is in my manual it shows a thing that looks like a plate its called a bypass valve and it holds the filter to the hydo block I don't remember that thing being in there,as I was putting it back together I thought it was strange the way the filter looked to short, but at the time I didn't have a manual to check it against.I'm going to look and see if it was not in there, if it is not, where would I get that thing?You can e-mail me at Junkmasterdave@Yahoo
Larry550
07-02-2005 16:07:04
 Re: oliver 550 hydraulic lift noise in reply to oliver dave, 07-02-2005 11:24:48
NAPA has the filters for the hydaulics. It is the same filter used for diesel fuel on the super 55 and 550 diesels.
J. Schwiebert
07-02-2005 19:29:42
 Re: oliver 550 hydraulic lift noise in reply to Larry550, 07-02-2005 16:07:04
Larry: The primary fuel filter for the tractors with the Bosch pump and the hydraulic filter for the Super 55 tractors built before 1957 are the same. After that, things changed with the hydraulic unit. His hydraulic filter is in front on the unit. And the 550 diesels say from the later part of 1960 use different fuel filters too. Questions?
1755
07-04-2005 16:59:55
 Re: oliver 550 hydraulic lift noise in reply to J. Schwiebert, 07-02-2005 19:29:42
the 10w30 or what ever was it non detergent if it was not is it foming and puting air in the system
Super 55
07-02-2005 10:47:14
John, when you asked if he changed the breather... are you talking about the fibre element with the small metal cap? If so, what does one use for the element now? Those are no longer available from AGCO.
oliver dave
07-01-2005 20:09:04
I also would like to know.If I have everything right, is this noise somthing I should worry about?
