OC3 front pully
ChrisL
07-01-2005 09:27:25
I had read somewhere that the front pulley is too weak for handling a hydro pump. I just purchased a OC that has hydro problem with lifting the blade. What do I need to look for as it relates to the front pulley being weak?
old
07-01-2005 11:02:40
 Re: OC3 front pully in reply to ChrisL, 07-01-2005 09:27:25
Well if thats true I may have a problem. Both my HG and my OC-3 have pumps run off the front of the crank shaft. I don't know it the pulleys are stock or where add on so that maight be why may system works so good
hector gemme
07-01-2005 10:13:21
HI I just have a oc3 for demolish in parts, tomorrow I will check the pully condition.
