1850 tach question
Alan K
06-30-2005 21:22:50
Can someone tell me where a person can get the tach drive ( small drive pin inside )? How does it come out? My cousins have an 1850 that the pin broke off inside (by the front cover). Is this a separate piece that can be bought? Can someone send me a parts breakdown of this? It is a perkins engine.
Fern(Mi)
07-01-2005 16:51:56
 Re: 1850 tach question in reply to Alan K, 06-30-2005 21:22:50
Have had same problem with 2 Ollies here. Our one fix was in replacement of initailing new drive cover assembly on front of block. But, tell your cousin to hang onto his socks" garters when he prices that part. The other Ollie fix is also the same part. That was our problems solutions. Good luck with your cousin"s problem
Fernan
Don-Wi
06-30-2005 21:32:11
Are you talking about the drive cable? If so, you need to know the length of the cable, and go to a white dealership to get a new one. You can just put the new drive cable in the old sheath, it's much easier than replacing the outer sheath as well. They usually pull out on the engine side of the cable.
Donovan from Wisconsin
