Electronic ingnition on 1850
IA Farmer
06-28-2005 18:28:55
Has anyone ever changed there points to one of the electronic kits like the ones advertised here? I have the original distributor. What do I do with the vacuum advance? Thanks.
1755
07-04-2005 16:04:24
 Re: Electronic ingnition on 1850 in reply to IA Farmer, 06-28-2005 18:28:55
When we looked in to this it was not that much more to get a new distributor from agco then you would not have to wory about the botom whereing out but you would still have pionts
ov corse this would not work if you just want electronic ignition
Johnnie T
06-28-2005 19:07:52
I replaced my dist with a Petronix electronic dist from Tom at O Brien Equip., also installed a Zenith carb and did away with the vacume advance, runs great.
Magiver
07-09-2005 18:06:02
 Re: Electronic ingnition on 1850 in reply to Johnnie T, 06-28-2005 19:07:52
Can I get more info on the electronic ingnition?
I have a 1850. It has a broken base plate and is hard to get the points adjusted.
