super 55 diesel
rodger
06-24-2005 15:50:41
made a big mistake.I ran my super 55 diesel out of fuel. Now I can't get it started. I know I have fuel to the pump. How do I get fuel to the cylinders? Is there a way I can be absolutely sure that the pump is pumping? How much cranking should it take to get fuel from the pump to injectors? Any and all ideas would be greatly appreciated. My first experience with diesel tractor.
Rodger
06-25-2005 20:46:31
 Re: super 55 diesel in reply to rodger, 06-24-2005 15:50:41
thanks so much for your help. lesson learned
MikeS55d
06-25-2005 16:41:59
Over the last 15 years I have run my S55 diesel out of fuel a few times. I have never had to resort to bleeding the air out (yet). I just cycle the little hand level on the lift pump (right side of engine) for a minute or two until I can hear the excess fuel sloshing back into the tank. The lever needs to have firm resistance through most of it's travel to get the fuel volume/stroke at it's maximum. If the lever doesn't have any resistance for 1/2 or more of it's stroke, crank over the engine and try the lever again. This will change the position of the fuel pump's actuating arm (driven by the camshaft) and allow you to manualy operate the pump. Once you hear fuel sloshing back into the tank, it should start right up.
RAB
06-25-2005 09:18:35
Your experience will hopefully teach you not to run out of fuel on these old tractors! Modern systems are self priming, so you can crank the air from the system. These older ones are not, and no amount of cranking will get it running unless you systematically bleed the system at each prescribed point until the fuel flow is free of air. Then to help further you can crack a connector at an injector until fuel flows (when cranking), then tighten up and she should start (if she hasn"t already, on the other cylinders). Bleed points will be on fuel filter(s), and on pump - not sure whether there is only one, or more on your pump. Use the mechanical lift pump to bleed the fuel through and remember you may need to get the cam positioned so the pump can be operated manually.
Hope this helps, and keep that tank full - you will probably have less trouble with water condensation in your fuel system if you do.
Regards, RAB
Mike (WA)
06-28-2005 08:36:33
 Re: super 55 diesel in reply to RAB, 06-25-2005 09:18:35
The "self-priming" feature on new rigs can be overrated, as well- I was trying to get the toolbox fuel tank on a '99 Dodge Cummins as empty as I could in preparation for removing it, and ran out of fuel (guage said I had 6 gallons left!). Cranked on it awhile (after refilling), then had it towed to the shop- Mechanic said if it runs out and you don't try to restart it at all, it will start about half the time after adding fuel. If you crank on it at all while empty, chances drop to near zero. Live and learn.
