Switching a White 2-135 from 1000 pto to a 540/100
goski
06-20-2005 10:25:05
I have a White 2-135 that is 1000 pto only. I dont want to trade it off due to it having most everything overhauled in last two years and I have my loader on it. I am wanting to find the back end or the pto housing that has the 540/1000 and try to get an idea if major job to switch and major expense. Anybody know of any good White salvage yards? Thank you in advance.
Felix
07-06-2005 23:06:14
 Re: Switching a White 2-135 from 1000 pto to a 540 in reply to goski, 06-20-2005 10:25:05
I had a 2-135 with the 1000 pto and you can not pull the pto shaft out like the dual speed units. The shaft is actually a few feet long. I used a pto adapter to run my baler and guess what happened at the first corner I turned too sharp- the tractor pto snapped right off. $1500 repair. NOT A GOOD IDEA AT ALL!
Mn. Dave
06-21-2005 04:49:40
I bought a 2-135 new in '79 and still have it. And if I ain't mistaken, it came standard with both a 540/1000 PTO. I switch between 540 and 1000 as my round baler takes 1000. Pull off the PTO guard with the 4 bolts and then grab the PTO shaft and yank it out, then look inside to see if you can see two different gear setups. If you have the two setups just find or order another short shaft to convert it.
Jim Meade
06-20-2005 15:35:15
You might try Colfax, IA, +1 (800) 284-3001
Franzen in Monmouth, IA +1 (563) 673-6631
That engine will have enough torque that you don't want to put too much power on a 540, anyway. You could buy a 1000-540 adapter pretty cheap and run the tractor a low RPM, perhaps?
