Cockshutt 40 or 50
Quebec Red
06-19-2005 16:58:25
In going over some specifications of these tractors, I am wondering how these units compared in the field to the Farmalls of the era, mainly a 40 and a 50 compared to a Super M with TA and IPTO. This tractor had a 264 inch motor verses a 277 in a 50 or the 230 inch 40. There were SMTAs and 40s and a few 50s around here, but that was before me. My elderly uncle said that a SM would easily outwork a MH 44, but does not recall going beside a Cockshutt. In silofilling or threshing on the belt the Farmalls did well. The IPTO of each brand had the same advantage. Not using the TA as a powershift, but as a means to have more ratios. I DO NOT want biased opinions or a color war, just some information as to how these old girls did in the real world. I think looking at the specs available that the tractors would be similar. I would like to imagine the field days of 1954-55.
Tim in NB
06-21-2005 16:01:05
 Re: Cockshutt 40 or 50 in reply to Quebec Red, 06-19-2005 16:58:25
Here is some Nebraska tractor test ratings using the SAE rating:
Farmall H Gas-drawbar:19.13, belt/pto:23.72
Farmall M Gas-drawbar:25.83, belt/pto:33.35
Farmall super H Gas-drawbar:22.38, belt/pto:29.42
Farmall super M Gas-drawbar:33.18, belt/pto:41.28
Massey 44 Gas -drawbar:31.02, belt/pto:39.98
Massey 44 spec. gas-drawbar:34.39, belt/pto:42.75
Cockshutt 40 Gas-drawbar:30.05, belt/pto:38.75
Cockshutt 50 Gas-drawbar:38.63, belt/pto:49.14
Don't forget that the SAE rated drawbar horsepower is 75% of calculated maximum and 85% for the belt/pto.
havvey
06-21-2005 09:10:57
they held there own, a torque amp is a tremendous advantage in a hard pull live power was an advantage in baliing etc. you will sometimes see a tractor that comes in the middle of two like between an h and an m so that is a tough call example an a john deere a will eat an h but is not quite up with an m each tractor has some advantage in some area is all in what you do. the other problem is if you look at what period they came out an h i believe 1939 big difference in something that hit the market in 55 like a massey 333 etc hope this helps
Mike (WA)
06-21-2005 08:19:38
Actually, I think I recall that the Cockshutt 35 (4 cylinder Hercules gas) was the all-time winner among wheel tractors in the Nebraska tractor tests as to percentage of its own weight it could pull.
Ohio Puller
06-20-2005 16:39:47
I spent over 25 years farming with my dad and brothers and we owned many different makes and modles of tractors over the years. I own two Cockshutts, a John Deere, and a Allis Chalmers now but don't farm now. I beleave one is about the same as another as long as your talking same size. I think it's all in what you like and what you want. I like the Cockshutts because not everyday you see one and not everybody has one. Just my opinion, and the best info you can get is from spec sheets.
Quebec Red
06-21-2005 16:22:38
 Re: Cockshutt 40 or 50 in reply to Ohio Puller, 06-20-2005 16:39:47
Thanks guys for the information. I think a Cockshutt 50 rowcrop would be pretty intimidating on a corn chopper, that six cylinder should really hang in. I remember Cockshutt 35s with the Perkins and wow power steering. Sure was a good seller compared to a Farmall 350 with the Continental motor. They were always hard starters and heavy smokers. QR
