My Cockshutt 1600 is a quitter.
Sprucegum
06-18-2005 07:10:53
My first tractor, the opportunity fell in my lap and now I'm trying to figure out what I got into.
Its a gas- starts and runs fine for a couple minutes. Its not overheating, charging system is good. Ignition wires look old and tired. Would a crack or short in the coil wire cause the sudden shut-off effect?
After a minute it starts again, could it be the coil itself? I haven't played with one of these for 40 years.
Thanks
MikeWisc
06-20-2005 05:11:56
 Re: My Cockshutt 1600 is a quitter. in reply to Sprucegum, 06-18-2005 07:10:53
For what it"s worth, my 1550 had the same problem. Started and ran fine until it warmed up. Then it quit an wouldn"t start until it cooled off. It was the coil. Replaced it and it has run fine since. Same problem with my 550. Put on a new coil and same result. Good luck.
Bill Johnson
06-18-2005 14:16:32
I just went through the same thing with my "new" Oliver 88. It turned out to be trash in the gas tank restricting the gas feed into the settling bowl. The bowl would stay full but the engine would quit. Sometimes enough gas would dribble through and sometimes not. If I blew back the line, it would run okay for a little while. I've removed the gas tank for cleaning.
Sprucegum
06-18-2005 18:06:07
 Re: My Cockshutt 1600 is a quitter. in reply to Bill Johnson, 06-18-2005 14:16:32
Thanks for the info. I had an old car that did that to me once, I should have remembered...
Sprucegum
06-18-2005 10:10:12
Thanks for the quick replies, the carb. clean is good advice.
The broken wire sounds like just the kind of problem I have here. I will check it out this afternoon and let you know how it works.
IF the rain lets up!
Leob
06-18-2005 09:46:12
I would take the carb apart and clean it very good. An in-line fuel filter is also a good idea.
j-bratto
06-18-2005 08:10:19
my brother 1600 oliver done this and it was the wire that go from the key to the starter thr wire broke in the rubber and when it was cold it was all right as soon as it warmed up the wire i guess would com a part. put new wire in and that end the problem . took me about a month to find it. good luck with yours
