Duals for 3-Digit tractors
good6742
06-16-2005 20:05:57
I have what I think is a cast adapter to put duals on the oliver cast center wheels. They look like the bolt up where the wheel weights would bolt on. Does anyone know anything about these cast hubs that allow you to put duals on a 3-digit oliver? I have a 770 and I think it would look neat with duals. Thanks,
Lance
Jim Meade
06-17-2005 21:26:46
 Re: Duals for 3-Digit tractors in reply to good6742, 06-16-2005 20:05:57
My friend has a set of dual extenders that he put on his show S77. They look for all the world like a cast iron top hat. Bolt the flanged side to the inner wheel and bolt a steel or cast rim to the top of the extender.
OlMax
06-17-2005 07:16:45
I used a couple sets on 2 1800's. I used what I think were M&W duals, pressed steel rims that had the same bolt pattern as the Oliver hubs. The extension hub did not have a collar that fit inside the bolt pattern to help support the weight of the tractor. I don't think it would be a good idea to used cast center rim set-up as the bolts would have to support the weight without the collar in the center. It was hard to keep the dual tight because of the lack of the collar support. Check the treads in the hubs to see if they are worn, they could be drilled out and replaced with stud and nut if the threads are not good. Make sure the tire is the same demension as a tire of the same size but different manufacture can be different height.
