Allied Loader on 1755 Oliver
CRW
06-16-2005 19:19:02
Has anyone ever put a 590 Allied loader on a 1755 ? The mounts all work, because the loader came off of a 2-70 White. The problem I"m having is where to tie into the hydraulics to work the valve. The valve has 3 lines that was hooked into the hydraulic system on the 2-70. One should be pressure and on should be return. What is the 3rd line for and where to I tie these lines into the tractor. Thanks
Don-Wi
06-16-2005 20:02:30
 Re: Allied Loader on 1755 Oliver in reply to CRW, 06-16-2005 19:19:02
The 1755 has closed cenetr hydraulics, and the 2-70 has open center. Most valves have a way to switch them from one to the other, but if you don't hook it up right you could be finding out how expensive a hyd. pump is. I don't know much about the valves so I won't claim to, I just know what not to do.
Donovan from Wisconsin
alberta dave
06-16-2005 19:35:33
I have an Allied 580 on my 1650 and my neighbor has a 590 on his 2-85. We both hook directly to the existing hydraulic ports on the tractor. Is there any chance you could post a picture of the valve and lines? Does the loader have a grapple?
CRW
06-17-2005 05:31:07
 Re: Allied Loader on 1755 Oliver in reply to alberta dave, 06-16-2005 19:35:33
I don't have any way of psting a pic right now, my printer/scanner is down. Where are the ports that you hooked into? I had a 1550 that had plugs in the side of the hydraulic housing that could be used, but I can't find any on this 1755. There is a Tee on the left side that I can get power from, but not sure if I can find a find a high pressure fitting that would replace the Tee with a 4 way Tee. Thanks
Don-Wi
06-17-2005 14:46:35
 Re: Allied Loader on 1755 Oliver in reply to CRW, 06-17-2005 05:31:07
the 17-18-1955's are MUCH different as far as hydraulics go. I beleive you tie into the line that wraps around the seat for pressure, there shoudl be a coupler in the line you could disconnect and put in a T. For the return, I'm not sure where to go w/ it, but others on here can tell you.
j105
06-18-2005 19:27:46
 Re: Allied Loader on 1755 Oliver in reply to Don-Wi, 06-17-2005 14:46:35
The retutn line goes into the back of the hyd unit. There is a plug just to the left of the top link bracket,near the base of the hyd unit. this port will allow free flow back into the hyd system. Also you can purchase a compression type tee fitting that can be installed in that wrap around steel line. of course it will require cutting that line. polish the line real good before installing.
