duals
hardscrabble
06-16-2005 17:45:38
I can think of at least 6 1850's, 1 1750, and a couple 1900's that had rear end and/or tranny failure. The one thing they all had in common was 18.4-34 duals. Was this also a problem in other regions? I'm in NW ND.
drsludge
06-16-2005 18:47:11
 Re: duals in reply to hardscrabble, 06-16-2005 17:45:38
Not really a problem,but were the duals mounted right? Under inflated so that when you went over rocks,trees the outside wheel didnt lift the tractor off the ground?
were the duals left on both sides while plowing with a semi-mount plow?
How many hours are we talking,I have seen some tractors from ND and they looked like they went 24-7.
We broke a axle on a 1850 but you could see that the old mounted picker that used to be one it had put a check in it.
Also thinking pull plow here but how many weights were hung off the side of the wheels so you could pull that 8 bottom pull plow?
hardscrabble
06-17-2005 18:11:29
 Re: duals in reply to drsludge, 06-16-2005 18:47:11
The general rule back then was to run 12 psi on the inside and 6 psi on the outside. But it did seem to me that these guys were pulling these tractors too hard. So it may have been plain and simple abuse. A couple of the guys removed their duals. They sacrificed traction, but no more repair bills. One farmer's 1850 was in the shop 3 times in 5000 hrs, before he traded it for an IH 1256.
