Thermostat for Oliver 77 gas
Rod H
09-09-1999 20:49:55
I can't get a thermostat from a White dealer so I bought a thermostat from a farm supply store. The threads on the one in the tractor are very fine - definitely not pipe thread whereas the one I bought has a courser thread - probably pipe thread. Where can I get a thermostat with the right threads? What kind of thread is the one in the tractor now?
Bob K
09-10-1999 19:14:53
 Re: thermostat for Oliver 77 gas in reply to Rod H, 09-09-1999 20:49:55
Do you mean thermostat?? or perhaps thermometer,
which has a bulb with a threaded backup nut. I
have a 77, and the thermOSTAT just drops in under
the top radiator hose neck
Rod H
09-11-1999 00:40:07
 Re: Re: thermostat for Oliver 77 gas in reply to Bob K, 09-10-1999 19:14:53
I meamt a thermometer gauge; not a thermostat. Thanks for pointing that out. The problem is that jobber replacements have a different type thread on the block end. White equipment doesnt have one for sale.
Dennis(WA)
09-11-1999 09:41:08
 Re: Re: Re: thermostat for Oliver 77 gas in reply to Rod H, 09-11-1999 00:40:07
I just put a new reproduction temp gauge on my 77. It should have a brass fitting pipe sleeve that the actual thermometer threads into. You should be able to find the right sleeve adapter fitting to fit the block and receive the thermometer. Try a good hardware store.
Rod H
09-13-1999 21:11:54
 Re: Re: Re: Re: thermostat for Oliver 77 gas in reply to Dennis(WA), 09-11-1999 09:41:08
You're right. A jobber product works just fine. I put one in yesterday. Thank you for the help.
