mystery part on 1800
rong
06-16-2005 09:43:28
When I removed the engine/clutch/hydrpower unit ther was a plate about 6" x 4" laying in the bottom of the frame underneath where the hydropower unit sets. The ends (short side)are cut at a diagonal and it has 2 slotted holes. Any idea?
WFE
06-16-2005 12:00:21
 Re: mystery part on 1800 in reply to rong, 06-16-2005 09:43:28
Probably a piece of scrap used to sandwich between the Hydra-Power and the bottom of the tub frame to support the unit. During the production of the 50 series, it was discovered that the Hydra-Power and later Over/Under units were too heavy for the bell housing alone to support cantilevered in place. Oliver's fix was to drill and tap a hole below the location of these units and install a bolt and a jam nut, used to support the weight of the H/P or O/U units so that the bell housings would not fatigue and crack over time. Existing units, like your 1800, were to have been fixed like this in the field, but apparently, someone came up with their own way to support the H/P by wedging a plate under the unit. Crude, but better than nothing I suppose. Now that it's removed, go ahead and drill and tap your own hole in that location to provide support for the unit as Oliver intended.
papabottum
06-16-2005 14:37:41
 Re: mystery part on 1800 in reply to WFE, 06-16-2005 12:00:21
I've seen one instance of the support bolt installed in the frame punching a perfectly round hole up through the bottom of the hydrapower.After that, we always put a thin flat plate on top of the bolt & below the hydrapower. I only saw the one instance of the hole-guess the bolt had more pressure than necessary.
