parts for a 53 oliver 550
John Manning
06-13-2005 20:20:38
Hi Folks,
Finally got my late fathers pride and joy running, but after many years of sitting I'm having some teathing problems so to speak. First of all, I was surfing one night and I came across a diagram for a bracket to replace the stock generator(beond repair) with a delco alternator, printed it but now can't find it. Honestly I think I can hide my own Easter eggs! anybody out there have that diagram? Also My water pump is leaking out the seal any suggestions.
Thanks in advance
J
Jim in IL
06-15-2005 05:28:10
 Re: parts for a 53 oliver 550 in reply to John Manning, 06-13-2005 20:20:38
Last year I replaced the waterpump on my "59 550. It was a pretty straight forward job. I was warned by a long time Oliver mechanic to stay away fron "Chineese" pumps. Also, the pump housing differs somewhat among 550's so check it closely if you get a replacement. Good Luck
J. Schwiebert
06-14-2005 14:58:47
First of all what is the problem with the generator? Second, not all 550 engines use the same waterpump so a serial number would help. I would not get a rebuilt pump, I would rebuild the one you have, can be done very easily. Next your tractor will just become newere unless you hit the wrong key. The first 550 tractors were built in 1958 Questions?
John Manning
06-14-2005 15:50:29
 Re: parts for a 53 oliver 550 in reply to J. Schwiebert, 06-14-2005 14:58:47
Finally some knowledge,, 58 huh,, was told it was a 53 but that could have been B.S. Serial number to follow, maybe you folks can tell me what I've got.
The Gen. is toast, bearings shot, commutator and armature worn badly and brush holders are damaged, field coils ok though, go figure.
As far as rebuilding the water pump, where do I get the parts?
And last but not least, I'm either going to restore or sell. I'm leaning toward the sell idea because of time pressures. I'm in New Brunswick Canada. The paint is warn (badly) but it's never been painted over, what's there is original. The only thing that wasn't up to snuff before it was parked is the PTO. The rest I'll repair before I hang a sign on it. What should I ask for it?? Ball park.
Might try to post a photo, Kinda' computer illiterate.
J
John Manning
06-15-2005 10:56:04
 Re: parts for a 53 oliver 550 in reply to John Manning, 06-14-2005 15:50:29
OK,, Serial # 70743-519
Specification # 35-202
The only other Identification #s are on the loader, I'm assuming that is for the loader. So guys what year is the old girl, gotta start somewhere.
Thanks again.
J
AB
06-15-2005 19:57:01
 Re: parts for a 53 oliver 550 in reply to John Manning, 06-15-2005 10:56:04
Korves Bros. in Illinois are a good parts source for the 550. Also there is a fella in Texas that has a lot of 55's and 550's he's parting out. I got a few things from him and was happy. He lists frequently on Ebay but you call him also. Search for 55 or 550 on ebay and you'll find his #.
