Reverse-o-Torc jerks forward
Mike Fraley
06-13-2005 13:51:00
I've got a 1969 Oliver White Industrial Backhoe with the reverse o torc transmission. The symptom: When pushing the forward pedal, the unit "jerks" into gear. If you want to go forward at a normal speed, it continues fine... continuous smooth power. But if you want to inch the machine forward, or creep slowly ahead, it jerks in and out of gear... In reverse, it works fine. A gentle push of the pedal, and the machine inches slowly backward. No problem. Here are the only clues: The unit was low on fluid (4.5 quarts to be exact) and appears to be draining from the torque converter back into the resevior when the machine is not running. According to the manual, this can be caused by the failure of the converter check valve. (The jerking occurs now, with the unit full.) Question: What's causing the jerking? Could it be caused by the converter check valve? How about the other two check valves on the opposite side? I'll be checking the rpm idle speed later today, but I believe it is fine... Any help here would be appreciated!
Thanks!
Mike
