Cockshutt 560 - what's it worth?
LH
06-11-2005 13:36:00
My dad's old tractor hadn't been started in 15 years. A friend came out, drained some hoses, cleaned some filters and had it running within an hour. Has some rust. Other than that, it actually runs good. Any idea of Canadian $$$?
cockshuttguy
06-13-2005 12:24:17
 Re: Cockshutt 560 - what's it worth? in reply to LH, 06-11-2005 13:36:00
Depends. I bought 3 560's and all the engines were bad. One was running and the lingo turned out to be a lie about the condition and the work that the tractor had been doing. The early 560's have a three main bearing crank assembly and are subject to breakage more than later models. I was able to salvage one head from three engines and the rest are salvage material. I imagine the engines were not maintained properly and the tractors were neglected. If your 560 has ps, 3-pt., awfe, pulley, and other goodies it is worth between 2500-3000. Lastly, that series of perkins engines were not the best that perkins has had to offer.
alberta dave
06-13-2005 12:08:09
What are the tires like? Where is the tractor? Is there a 3 pt hitch?
Mike (WA)
06-12-2005 08:53:53
Depends on condition, diesel or gas, 3 point or not, power steering, etc.- but with straight tin and running OK, probably $2500 Cdn.
mikefri
06-12-2005 10:55:33
 Re: Cockshutt 560 - what's it worth? in reply to Mike (WA), 06-12-2005 08:53:53
the cockshutt 560 was ONLY built as a diesel tractor.
