Oil Question
mrunion
06-09-2005 12:59:12
I want to change the oil on my newly acquired 550. I called the dealer/mechanic that did the work on it and inquired as to what they run in it. I also have downloaded a manual on the tractor.
The dealer/mechanic said they used 10W-30 in the engine and 68W in the transaxle/trans and in the power steering.
OK, I'm not so tractor smart but I haven't heard of 68-weight oil. The dealer sells it for $27 for 5 gal., so it's not all that expensive.
Is this what you guys use?
Thanx,
Matt
Jim@concordfarms.
06-11-2005 08:20:44
 Re: Oil Question in reply to mrunion, 06-09-2005 12:59:12
Mechanic was probably talking about ISO 68 hydraulic oil which, if I remember right, is 20W. Nowadays, most likely the same as the universal oils. Check with a reputable oil jobber for sure. Jim.
mrunion
06-12-2005 14:19:16
 Re: Oil Question in reply to Jim@concordfarms., 06-11-2005 08:20:44
Excellent. Thanx!
