Oliver 1855 Hydro shift
Darrell_W
06-08-2005 20:15:26
Just bought a 1974 1855 Dsl. My brother was changing fluids and is wondering what is recommended for use in the Hydro shift. He was told to use a universal hydraulic trans fluid.
His concern is that he hears a slight growl when under load in 3rd range, less in 2nd range and good in 1st.
Any ideas or help on this would be helpful. The service manual is on order and hasn"t arrived yet. Hopefully not a gear problem.... Thanks
Johnnie T
06-09-2005 18:02:17
 Re: Oliver 1855 Hydro shift in reply to Darrell_W, 06-08-2005 20:15:26
I have been running 30wt hyd. oil in all of mine in S Texas for years with no problems
ejr-IA.
06-09-2005 17:02:50
Check the chain and coupler for wear.
L Klingler
06-09-2005 09:21:58
I have only used Dextron, my dad only used Dextron, my pappy only used Dextron. Larry
Dean Barker
06-08-2005 20:33:25
Universal Hydraulic fluid will work just fine; later over/under hydraul transmissions were shipped from the factory with hydraulic fluid. You should attend to the noise before further damage is done. It probably is the input shaft bearing or possibly one of the other bearings.
