re-1550 hyd
hoot66
06-08-2005 13:09:34
1550 3pt. raises allright but will not hold. Shut off the engine and it will drop all the way in about 6 -7 seconds. The manual says it could be the thermal relief valve. I dont see anything that looks like the picture
J. Schwiebert
06-08-2005 14:58:15
 Re: re-1550 hyd in reply to hoot66, 06-08-2005 13:09:34
It could also be in the top spool(lowering spool) of the servo valve. What picture and what manual are you looking at? It may also be that the high pressure elbow on the shock protection valve has cracked. How well do you understand the unit.
hoot66
06-08-2005 15:34:22
 Re: re-1550 hyd in reply to J. Schwiebert, 06-08-2005 14:58:15
J. I am not very familiar with the unit . This and one more will make 2. I have an I&T manual for 1550&1650
Larry from MD
06-08-2005 17:02:56
 Re: re-1550 hyd in reply to hoot66, 06-08-2005 15:34:22
For this problem the checkball and spring in the servo valve is most common.This ball is pushed open by the lowering spool and the 1/8 rod.Useually the ball just gets stuck in the end of the spring.
