540 Cockshutt Serial Number
Texas Denny
06-08-2005 08:26:29
Where do you look for the serial number of a 540 Cockshutt?
Thanks,
J. Schwiebert
06-08-2005 09:45:36
 Re: 540 Cockshutt Serial Number in reply to Texas Denny, 06-08-2005 08:26:29
Stamped in the top of the frame that supports the engine. It will be 2 letters than the number. The first letter will be the letter A. The second letter will be the year of production starting with the letter M. Then the 4 numbers. It is on the right side if I remember correctly. Also check to see if it is factory 12 volt. The AM & AN models are 6 volt the others are 12 volt. There are little changes in them just as there are in everyone elses models. Questions?
