pulling question
nimrod
06-06-2005 20:03:53
I know a guy that pulls 6000lb class with his(as he puts it) slighly "stock" 88, in 3rd gear, how many hp would anyone guess you would need, he claims he has only 70hp, and I have a 77 with 65 hp, and can't touch him! Maybe I'm doing something wrong, I run 14.9x38, and he runs 18.4x38.
Jak
06-09-2005 11:49:39
 Re: pulling question in reply to nimrod, 06-06-2005 20:03:53
My super 88 has 65 hp at 130 psi per cylinder.I run in second up in 6000lbs but drop back in first in 65 and 7 with 15.5's.It will blow the horn in second gear almost up to the 100 ft cones.He had a lot more than 65 hp running third gear with 18.4 38's.
310 puller
06-07-2005 15:26:12
Either he stroked it or it has a 310 in it. No way he pulling 3rd with 18.4 38s in a slightly stock 88.
Bob2
06-06-2005 21:41:44
If he is pulling 6000# class in 3rd, probably has a 10/47 ratio, means he is going around 5 mph, he has to have at the very least 90-95 horse power to turn 18-38's. Number one rule around pulls, beleive nothing your told and dont blink much, or you cant beleive much of what ya see either
old
06-06-2005 20:56:03
How are you getting 65HP from a 77 since it only puts out around 38 from the factory??
stroker 88
06-07-2005 20:06:33
 Re: pulling question in reply to old, 06-06-2005 20:56:03
there is a big difference between stock and ones that are prepaired for pulling. we crowd 35 hp with stock 66 and 40 hp with 70's.
nimrod
06-07-2005 13:49:34
I did extensive head work, 1550 head, and custom cam, m&w pistons, thats the most of it.alittle detail work too.
