Super 88 Sticking Clutch
Nathan Horton
09-08-1999 21:03:34
I have a Super 88 that will not let you push in the clutch to shift. You can start it and run it in gear and it will run but off course you can't stop or shift. Does anybody know what must be done to get rid of this problem?
Bob M
09-09-1999 07:45:20
 Re: Super 88 Sticking Clutch in reply to Nathan Horton, 09-08-1999 21:03:34
Does the clutch pedal not move, or can you depress the pedal OK but it doesn't release the clutch?
Nathan Horton
09-10-1999 18:34:09
 Re: Re: Super 88 Sticking Clutch in reply to Bob M, 09-09-1999 07:45:20
Bob The clutch pedal can be pushed down and it can be shifted into any gear as long as the engine is off. once the motor is running pushing the pedal down will disengage the clutch.
Bob M
09-13-1999 04:56:07
 Re: Re: Re: Super 88 Sticking Clutch in reply to Nathan Horton, 09-10-1999 18:34:09
If the clutch pedal moves OK but the clutch stays engaged, the problem is the clutch disc is stuck to the flywheel/pressure plate. Not unusual for a tractor that has been sitting unused for a while - these parts get stuck together with rust.
If you have another tractor, do this: Make sure the clutch linkage is properly adjusted. Remove the coil wire (so the motor can't start). Hook a chain so you can pull the tractor. Put the Super 88 in a high gear (5 or 6), step on the clutch pedal and slowly pull the tractor forward. If the clutch does not break free after 20 or 30 feet, switch ends and pull the tractor backward. It may take several tries of forward and reverse pulling before the clutch lets go.
If you don't have a way to pull the Super 88, this also works. (Use only on a hard, level road with no traffic!): Make sure the clutch linkage is adjusted and both brakes are in good shape. Start the tractor, get it rolling in road gear (best way to do this is to idle the engine and 'snap shift' it upward gear by gear until it's in high). Now run the motor about 1/2 throttle, depress the clutch and try to stall the engine using the brakes. The clutch should break free.
Good luck!
