Fewest Tractors Made
Erickson
06-02-2005 08:44:23
Does anyone know what tractor Oliver made the fewest of commercially?
m kuhns
06-03-2005 08:13:13
 Re: Fewest Tractors Made in reply to Erickson, 06-02-2005 08:44:23
A 2155 and 2055 is not a true oliver so I don't know if this counts. There are only around 210 2155's and about the same number 2055's These were leftover MM's
scottf
06-02-2005 21:15:27
Great question. Here's a couple more.
1. Oliver 995 Lugmatic. Darn few made. Maybe 50. 2. Oliver Super 99 Gas. They say only 25 were made.
3. Early Hi-Crops. Three and four digit models a fairly common. 4. Any Oliver model with the Hydraulic Front Wheel Assist.
5. 80 Diesel. There is only one Standard known to exist today.
6. There are not a lot of Mechanical Front Wheel Assist.
7. Most of the early industrial models are far and few between.
8. Airport 25 model. 9. Someone all ready mentioned the Super 99 GM so will mention the 990.
10. They only made 2150s or 2050s two years.
The hardest one to find is probably any of the Hydraulic Front Wheel Assist models. They never did make many and fewer still are left intact. The larger models are the most unsual.
good6742
06-02-2005 22:03:41
 Re: Fewest Tractors Made in reply to scottf, 06-02-2005 21:15:27
We have a 995 Industrial. Does anyone know how many of these were made?
scottf
06-03-2005 18:17:44
 Re: Fewest Tractors Made in reply to good6742, 06-02-2005 22:03:41
Nobody can tell you how many 995s were made. Until they go through all the build cards and break down the data and list everything out we will never know for sure. Some of these so called rare tractors are just about as common as dirt compared to a 995. Based on the numbers of 995 left today I would guess that less than 50 were made. It was an extremely expensive tractor in it's day. Ironically, the "Industrial" 995 is far more common than an Ag version. They sold a lot of 995 to pull scrapers and such. So the Ag version is the rarest of the 995s. I was wondering how you determined your 995 is an Industrial.
Boiler Rick
07-31-2005 19:59:50
 Re: Fewest Tractors Made in reply to scottf, 06-03-2005 18:17:44
Scott--I"m new to this. How do I tell an ag version from an industrial? Any help is appreciated. Thanks! Rick
good6742
06-03-2005 20:52:55
It has a straight front axle instead of the ag ones having a slight arch to them. The straight front axle is used on the industrials because of the taller front 20" cast wheels with 20" tires. This is what I believe makes it an industrial.
Joel van sciver
06-08-2005 09:40:35
 Re: Fewest Tractors Made oliver 950 in reply to good6742, 06-03-2005 20:52:55
How many oliver 950 double stick hand clutch with a diesel motor it is completly redone, how many were made and how much is it worth?
scottf
06-04-2005 19:54:35
 Re: Fewest Tractors Made in reply to good6742, 06-03-2005 20:52:55
I would consider it an Industrial too. Was it ever painted yellow? Suppose you have 23.1 x 26 rear tires? Does it have two stick shifts? Does it have a foot throttle?
good6742
06-05-2005 05:06:40
 Re: Fewest Tractors Made in reply to scottf, 06-04-2005 19:54:35
Yes it was paited yellow and it does have the two stick trans and foot throttle.
mowr
06-02-2005 20:07:11
I"ve read that Oliver 80 diesel row-crops are scarce.
RickB
06-02-2005 17:39:53
My 660 is one of less than 1500.
Getting Started
06-03-2005 13:06:38
 Re: Fewest Tractors Made in reply to RickB, 06-02-2005 17:39:53
My Oliver 440 Gas is one of only 700 ever made.
oliverfan
06-02-2005 11:48:25
Oliver " Out of tomorrow " (1 built in approx 1955) This does't really belong as a answer to your question. I just threw it in. Oliver Twin 880. Though to have built 5 or less. One sold in Calif. Others though to be scraped out.
Oliver Hart Parr 70 industrial (only 2 built)
Oliver 18 industrial (only 6 built)
spud head
06-02-2005 20:11:22
 Re: Fewest Tractors Made in reply to oliverfan, 06-02-2005 11:48:25
I learn something every day, thanks for the info.I appreciate learning that bit of oliver history.
Texas Denny
06-02-2005 10:27:26
My guesses would be the 900 Industrial, Super 99 or the Super 44. But I don't have a reference with production quantities.
Joel van sciver
06-03-2005 05:07:08
 Re: Fewest Tractors Made in reply to Texas Denny, 06-02-2005 10:27:26
I have a Oliver 950 diesel double stick hand clutch. Have not seen many of these around. just wondering how many were made.
