Super55 3-point stabilizer question
John In WI
09-08-1999 07:19:34
I'm looking for a couple of stabilizer arms for
an Oliver Super55. These would prevent my Bush Hog
and rear blade from swaying. I can't find one in
my parts book and no luck with aftermarket(Speeco)
Does anybody have ideas as to what I could use or
if this is even an option? I figure the arms would
attach to the bracket below the axle under the fender bracket and then to the lower 3-point pin.
Thanks for your help with this.
John
Dave
09-17-1999 17:26:18
 Re: Super55 3-point stabilizer question in reply to John In WI, 09-08-1999 07:19:34
Besides stabilizers, and thought better by some, is a mower deck height stabilizer kit made by ZERCO, Springfield, MO. This is a set of chains and attaching straps from the tractor top link point to the bush hog lower lift pins. The kit can be easily adjusted, lets you return the bush hog to the same height, and takes strain off the lift when down. Plus while returning the bush hog to a center position like the regular stabilizers maintain, it gives you a bit of flexibility in turns that might help avoid breaking parts.
John
09-09-1999 04:54:09
 Re: Re: Super55 3-point stabilizer question in reply to Pete in Post Falls, 09-08-1999 22:13:35
I bought a set at Central Tractor Farm & Family which I use on my 550. If I remember right, I had to buy the complete set which included the brackets and pins for under the axels.
Pete in Post Falls
09-09-1999 13:02:15
 Re: Re: Re: Super55 3-point stabilizer question in reply to John, 09-09-1999 04:54:09
That sounds like what my picture shows. You could use that as a model and build more. Good Luck.
Pete in Post Falls
