brake question on 1850
mud
05-30-2005 18:01:40
Can anybody tell me if there are differant thicknesses for the shims used with the brakes?
We bought new brake dics from NAPA.
We bought new shims from AGCO. The shims appear to be too thin, or the discs are too thick.
Heck, I don't know and I'm about to pull out what little hair I got left.
mud
Myron KY
05-30-2005 18:25:46
 Re: brake question on 1850 in reply to mud, 05-30-2005 18:01:40
How many shims are you using? I have 3 per side with new pads. One Oliver original and two home made ones per side. My home made ones may be a little thicker than the originals. If you only have one shim per side, your gonna need more shims.
My 2�,
Myron KY
J.Schwiebert
05-30-2005 18:20:43
Did you loosen the adjusters? How many shims? Put enough on one side so that there is no offset in the cover in other words the thickness of the shims would make the cover even. Start from there. If you do not have enough shims for both sides do one side and see how many you need.
