lp injection on an 88?
patrick cavanau
05-30-2005 15:45:44
has anyone ever heard of adding lp injection to an 88 diesel? a pulling buddy suggested i look into it but i haven't been able to find any info on it. thanks.
1800c Tom
05-31-2005 19:22:53
 Re: lp injection on an 88? in reply to patrick cavanaugh, 05-30-2005 15:45:44
A customer I had ran Minni"s. Whenever he bought a different diesel model, he would pick up a LP kit called Red Roster Power Booster. He got them in Desmoines Ia.
Tramway Guy
05-31-2005 18:58:54
A very long time ago, I did this with an 88D for an "out of field" tractor pull. I used a little propane tank and valve from a 'Bernz-o-matic' hand torch. Just took off the soldering head and ran a copper line to the intake manifold where the 1/8" pipe plug was normally installed. I just turned it on when I started down the track and yes, it gained noticeably more power. Probably about the same as radically overfueling - - but without all the smoke. When I finished the run, the copper line was coated with frost from the refrigeration effect of the liquid propane converting to a gas (I ran it upside down, with the valve on the bottom).
ejr-IA.
05-31-2005 09:54:43
My daddy inlaw had this set up on his 88d I'll have to look at it and see how it worked.
RWT
05-30-2005 20:18:11
I have heard of it but cannot tell you much. When I was a kid Tractor Supply sent out a catalog that had what was called a 'torque topper' to be kicked in for tough spots.
If I remember correctly a guy I knew tried to inject propane in his K series Cummins. Now you have to know that this is one of those guys that if a little did some good a whole lot would do a whole lot of good.
I think he cracked all the heads. I know it didn't go well.
I know this doesn't help much but I guess I am trying to say be careful.
RT
