pulsating oil pressure on 770
Joel H.
05-29-2005 17:22:35
I just overhauled my 770 this winter. I put in new sleeves and pistons,had the crank cut, new rod and main bearings. I just finally finished it up and got it running. The tractor doesn't have an oil pressure gauge just a light. So I went to the farm store and bought a $6.00 sprayer gauge and screwed it into the main oil galley on the side of the engine. The gauge really bounces alot. It usually bounces between 20 to 35 psi but once in awhile, at around 1400 rpm the gauge really goes nuts and bounces between 5 and 45 psi. The oil light stays off so if I wouldn't have put the gauge in I wouldn't have known this. But I wanted to see what kind of oil pressure it had. The mechanic at our agco dealer thought that since I used a sprayer gauge that it had a larger orfice and was picking up the oil pump pulsations. I don't know, have any of you guys ever had anything like this? Is this just typical or is there possibly something wrong? I cleaned out all the oil passages real good while I had the motor apart. And I had the oil pressure spring and plunger out and cleaned that up real good too. Thanks for any help. Joel
Larry from MD
05-30-2005 04:43:41
 Re: pulsating oil pressure on 770 in reply to Joel H., 05-29-2005 17:22:35
The gallery does plus like that.If you install a larger hose to the gauge on a S77 it will pulse wildly.Your oil preasure is fine just remove the new gauge.
old
05-29-2005 19:49:00
I'd say its the wrong type of guage, gauges are made for one type of thing, I.E. oil preassure for just that, air preassure for the and what you put there for what it was made for. Bite the bullet and buy an oil preassure guage, costs less then $20 at an auto parts store. Don't ganble on an idiot light.
