? for j. schwiebert on 550 pto
deene
05-28-2005 18:58:40
i engaged clutch on 550 pto and turned like you said and it does turn the clutch pack...where to next?..thanks for your help
J. Schwiebert
05-30-2005 02:36:42
 Re: ? for j. schwiebert on 550 pto in reply to deene, 05-28-2005 18:58:40
Let me guess. It did not turn the engine over. That should anser your question that the shaft through the final drive is not broke. Hook up to an implement, ingage the PTO,pull the coil wire crank the starter and see if you can here any stange noise from the center section or look underneath and see what is trying to turn. Send me a phone number.
