Oliver 1450 4 x 4
ChrisL
05-28-2005 09:30:01
Hello, I have a line on a 1967 Oliver 1450 4X4 tractor. I don�t know much about 1450 other then it seems to be a relatively rare tractor.
This particular tractor runs and is currently working mowing fields. The front drive is not working due to a broken CV joint.
If anyone can help with information about a 1450, would I be able to find parts to repair the front drive especially a CV joint�I understand the motor is a fiat 4 cly diesel what should I expect to pay for such a machine ? any info would help me
Carlton Grambo
05-30-2005 21:08:06
 Re: Oliver 1450 4 x 4 in reply to ChrisL, 05-28-2005 09:30:01
I thought the 50's were David Browns.
icesweeper
05-29-2005 08:39:06
You may want to visit this site before you write the check.
icesweeper
05-29-2005 08:40:01
 Re: Oliver 1450 4 x 4 in reply to icesweeper, 05-29-2005 08:39:06
Let's try that again.
http://www.sphosting.com/dsl/fiat.html
D13
05-29-2005 07:10:52
Parts are available for the 55 and 65 versions from Agco (a version or two of these were also sold as Allis'). Don't know about the 50's, there were a lot of changes between '50 and '55 series.. Bring a BIG wallet - they wanted $90 for the key switch. I put in a $10 switch and a $15 light switch/relay and got a better system.
If the CV is out a good driveshaft shop will probably be able to replace it with a different unit cheaper than the Agco part. I found the local drive shaft guys were 75% cheaper than the dealers.
J. Schwiebert
05-28-2005 18:05:01
Does anybody know who made the front wheel assist system for them? I got some feedback on this before and I do not know where you live, I thought they were a tough reliable tractor. Only problem at first and they changed that was having enough cold cranking amps. Bit this is 30 years later.
dwm
05-28-2005 14:40:00
The 12XX, 13XX, and 1450 series Olivers were actually Fiat tractors imported and re-badged as Olivers. Opinions vary on them. This was done starting in the mid-60s through the early 70s. I believe the 1250 equates to a Fiat 415, but I don't know what the 1450's corresponding number is. If you can find that, it would likely increase your chances of getting parts. You might also do a search in the archives and do some reading there. Good luck.
chparks
05-29-2005 19:36:22
 Re: Oliver 1450 4 x 4 in reply to dwm, 05-28-2005 14:40:00
The advice of iceseeper is good. Click on first
picture on left parts for Fiat Tractors then down to Fiat Tractor Buy's Guide.
