pto strength on 550
deene
05-25-2005 20:30:29
getting ready this wekend to put a brushog on the 550...i do some work for others and currently use an industrial 424 int...the 550 has pwr steering and nebraska tests show more hp with the oli plus i like olivers better..however that being said i have read on this forum that the pto clutches tend to go out if used regularly..is this true?..bought an 88 oli from a neighbor that runs a 12 ft. cutter with his 550 and says that its not true..says i need to keep it adjusted...i have an original dealers shop manual and it tells how to replace the clutches but not adjust them..this old guy said there is a plate that you remove and do this?..any help would greatly be appreciated as i would like to have it as best as possible before i get out there and have problems..would hate to go back to the int with no power steering..also what about the hyd system and such...do they hold up as well also?..thanks for the help and comments
J. Schwiebert
05-26-2005 02:06:45
 Re: pto strength on 550 in reply to deene, 05-25-2005 20:30:29
How much effort does it take to snap the PTO handle over center? There are a few 550's left around here and they probably still have the original PTO clutch in them so keeping the adjustment correct is the key. Check that shop manual again or order an operators manual from Charles City.
jake3
05-26-2005 08:51:04
 Re: pto strength on 550 in reply to J. Schwiebert, 05-26-2005 02:06:45
The adjustment is accesed by removing the plate on the underside and using2 long screwdrivers. As far as lubrcation there is a zerk on the right side of the transmission, this lubricates the release collar and should be done every 5 hrs of pto use. The lever should require 35# of force to lock the over center toggle [when it snaps into lock pos]. I have the CD if a picture might help.
