60 oil pressure
Joshua
05-23-2005 16:21:43
I recently left a post about snapping off the oil through head bolt, and not getting oil pressure up there. I got the head bolt out, but does anyone have any idea on why there is no oil pressure at the rockers, and what do I need to do to get some. There is alot of oil pressure at the pressure port for the gauge...Thanks alot...-Josh
Larry from MD
05-24-2005 09:04:54
 Re: 60 oil pressure in reply to Joshua, 05-23-2005 16:21:43
The oil preasure to the head is regulated by the front main bearing.you will have to pull the pan and clean out the holes and see that they are lined up.
Larry from MD
05-24-2005 11:24:34
 Re: 60 oil pressure in reply to Larry from MD, 05-24-2005 09:04:54
Oops that should be rear main bearing.
