Oliver Track Loader
Bob N.Y.
05-22-2005 09:22:42
A neighbor has this machine and needs to put new rod bearings in it. It has a 3 cylinder gas engine. The I.D. tags have been painted over and one is somewhat damaged. The engine tag says: GD-130, serial# 8750436. The tag on the chasis says: MODEL OC-46-3G and I think the serial# is 1WF-716. Can anyone tell me the year of this machine and the make of the engine? Thanks.
Bob N.Y.
05-22-2005 14:39:03
 Re: Oliver Track Loader in reply to Bob N.Y., 05-22-2005 09:22:42
Thanks for the info. I will pass it on.
old
05-22-2005 12:09:10
You can also get a lot of info at cletrac.org
Super 55
05-22-2005 11:30:16
Did a search and found this info from Albert C. Duroe. "You have a DD198 Hercules engine, parts are availuable from Landis Zimmerman @ 717 738 2573"
Zimmerman Oliver-Clectrac has a webpage.
Bob N.Y.
05-23-2005 06:43:10
 Re: Oliver Track Loader in reply to Super 55, 05-22-2005 11:30:16
What does the GD-130 on the engine tag mean?
Harry D.
05-23-2005 16:51:15
 Re: Oliver Track Loader in reply to Bob N.Y., 05-23-2005 06:43:10
The GD 130 is the model no. of the 3 cylinder gasoline engine used in the OC4 and Oc 46 crawlers. The 198 cubic in. engine is the 4 cylinder engine used in the OC9/96 series. [Later 9 series tractors built in Charles City used 212 cu.in. engine] the engines were built by Hercules, I would start at a NAPA store or good engine rebuilder with the model#, S/N and the Hercules name and see if the can find parts.
Bob N.Y.
05-24-2005 17:30:15
 Re: Oliver Track Loader in reply to Harry D., 05-23-2005 16:51:15
Thanks for clarifying that. I thought it was a 130 engine.
J. Schwiebert
05-24-2005 18:17:23
 Re: Oliver Track Loader in reply to Bob N.Y., 05-24-2005 17:30:15
Check the size of the crank. I have both the F-M and Clevite bearing numbers if you need them. You should have the engine with the 2 inch crank pin.
