77 RC serial #
Ed Brandt
05-21-2005 14:52:51
Just picked up 77 RC with serial# 32743-C77D...any help...doesn't match list on this site..
J. Schwiebert
05-21-2005 17:54:59
 Re: 77 RC serial # in reply to Ed Brandt, 05-21-2005 14:52:51
Check the tag again. You are missing one digit, most likely it is also after the first three numbers. It is either a late 1949 or early 1950 depending on which number you are missing. J
Ed Brandt
05-22-2005 11:56:29
 Re: 77 RC serial # in reply to J. Schwiebert, 05-21-2005 17:54:59
yep...your right..found a worn off 7 so the number is 327437-C-77-D Thanks for the help
6077
05-22-2005 12:38:41
 Re: 77 RC serial # in reply to Ed Brandt, 05-22-2005 11:56:29
where was the serial # at on the tractor
Ed Brandt
05-22-2005 15:54:14
 Re: 77 RC serial # in reply to 6077, 05-22-2005 12:38:41
The number was located on plate on trans housing,under floor pan ahead of rear.Couldnt read last 7 till clean it quite well.
Ed Brandt
05-22-2005 15:54:00
