Oliver 90 Steering Gears
Agrogeek
05-21-2005 10:00:55
Hello. My dad and I are working on my grandpa's old Oliver 90. The motor has been, and still is, stuck for 20 years. It is a complete tractor with good rubber and relatively complete sheetmetal.
However, as we were towing it home, the steering ceased working. We believe it is a stripped gear and are wondering if this part is the same as another Oliver model (due to the scarcity of the 90). The steering wheel turns in one direction freely and has almost infinite resistance in the other. The front wheels will turn if you turn them manually. It is a wheatland model, if that matters.
Thanks for your help. Any other information on the 90 is also appreciated.
Lee W
05-23-2005 05:56:29
 Re: Oliver 90 Steering Gears in reply to Agrogeek, 05-21-2005 10:00:55
Check the top bearing on the steering shaft, it will also cause the probleems you are having.
Jim Kline
05-21-2005 10:25:22
Same steering gear as a 99. I should have a good gear. If interested, call 937-981-3985 after dark.
