5 gear blowing oil
Larry NE IL
05-19-2005 20:04:33
My HP 70 5 gear was put together from 2 engines. The head was supposed to have had a valve job a few years back. Looks like it, I just cleaned some surface rust off and reseated the valves. The block I bought from a friend who said the engine was overhauled less than a year from when he got it. Pulled some bearings and checked cylinders, all looked to be almost new. When I started it and it warmed up, it blew blue smoke and large spats of oil all over the place. I'm thinking that the valve guides weren't replaced. It's got good compression. After running it for :30 min I pulled the valve cover off and there was still significant oil on the head like maby there is too much leaking from the tappets or the oil can't get away fast enough.
any ideas b4 I pull the head are appreciated.
Larry NE IL
john holcomb
05-20-2005 10:46:08
 Re: 5 gear blowing oil in reply to Larry NE IL, 05-19-2005 20:04:33
Larry,
Check the return route, the block may not have been boiled or the wrong head gasket could have been installed. I you have alot of oil on the top then you most likley have a plugged return. Call me if you need more help. John
