1800 motor removal help
lost
05-16-2005 18:46:42
I have taken out all the motor mount bolts and the bolts that attach the "plate" to the clutch housing. I have gotten seperation from the clutch housing of about 1.75" but it will not seperate from the clutch housing. I have place a wedge inthe gap but I hate to break something. Is their something I am missing or is this typically a difficult task.
Thanks for your assistance!
CEB
05-18-2005 10:18:09
 Re: 1800 motor removal help in reply to lost, 05-16-2005 18:46:42
Put those bolts back in. You pull the clutch housing apart after removing the engine/two speed/clutch as a unit-just like wrenchbender said. Also, I hope that you didn't attach a hoist and try to pull anything out while the input shaft was still in the tractor! If so, then you could have bent the input shaft and then you're really screwed. Always buy a manual and read it before attempting a big job like that!
Wrenchbender
05-17-2005 05:05:09
It is easier to remove the engine and clutch housing/hydra-power as one unit and then seperate the two after the engine is out. WB.
Tramway Guy
05-16-2005 19:20:58
If you haven"t already, you need to remove the PTO/Hydraulic drive shaft, which is done from the rear of the tractor. And if you don"t have one, you should have a manual of some kind.
LOST
05-17-2005 10:41:46
 Re: 1800 motor removal help in reply to Tramway Guy, 05-16-2005 19:20:58
Got a manual. Looks like just the upper drive shaft comes out? It also noted neeeding a special puller for the shaft - would you have any guidance on that? I'm curious, how does that shaft keep the motor from coming out?
Thanks
lost
05-17-2005 05:34:48
Your advice is sound. Obviously this is a little different than I am used to. Will go ge a manual today.
Thanks
oleblu
05-16-2005 19:20:44
Are you aware that you need to remove the PTO shaft before removing the engine??? If you haven't, set the engine back down on the mounting pads and take out the PTO shaft.
