88 pto lever
warren oliver a
05-14-2005 17:49:28
Just brought home an 88 row crop today to restore for my dad it is a 48 model and we converted to 12 volt tonight but the pto lever is on the left side as you sit in the seat and it has a box seat with spring cushion is this normal or did someone buy chance switch it for pupose any ideas on pto and seat
J. Schwiebert
05-14-2005 20:11:02
 Re: 88 pto lever in reply to warren oliver at heart, 05-14-2005 17:49:28
When the 88 was introduced the PTO handles were on the left side. The box spring seat was also standard. When the other style seat was installed the handle moved to the otherside. Also your handle is or should be a casting and not a welded steel assembly. Questions?
05-16-2005 08:10:19
 Re: 88 pto lever in reply to J. Schwiebert, 05-14-2005 20:11:02
how can we find out if there were diesels made that year or were they all gas models was wondering and possibly out of the 2900 made what are the odds of having one
J. Schwiebert
05-16-2005 14:46:11
 Re: 88 pto lever in reply to warren oliver at heart, 05-16-2005 08:10:19
Simple answer. The diesel was introduced in 1950. Yea I know there is a book in the local library about a 1948 diesel. Trouble is the tractor is a very late 51 model or very early 52. More interestin would be how many kerosene burners were made. Questions?
05-15-2005 10:48:29
thanks for the info this is a tractor that is going to be a rebuild for my parents 50th anniversay. I have never seen this before it is a 48 modle with serial 123103 which is a late model a freind is going to a swap meet this next week to pick up acouple of things that are missing.
Bill Johnson
05-14-2005 19:28:11
Also, my old Oliver has the standard type seat that uses the rubber seat springs.
Bill Johnson
05-14-2005 18:57:13
Warren,
You'll need to get the correct information from someone more knowledgeable than myself, but I have an early 88 and the PTO lever is on the left side on mine also.
