Super 88 manifolds
Douglas Jones
05-14-2005 16:46:20
I have a super 88 comercial loader converted to a backhoe. The number plate on tractor has been removed. The numbers on the motor are 190320H with 1K100E under it. It has a Zenith carb.The loder was a modle 88WT serial 483. I need manifolds for it and am not sure which intake it should be. Exhaust seem to be all the same. Tractor runs fine but manifolds are shot.
A.P.
05-14-2005 18:32:33
 Re: Super 88 manifolds in reply to Douglas Jones, 05-14-2005 16:46:20
Check the spacing (center to center) of the carb mounting bolts/studs to the mainfold. If it is closer together than 3 1/2" then you will need a regular 88/Super 88 manifold. If it is 3 1/2" then you can use an 880/1600/1650 intake manifold.
Douglas Jones
05-14-2005 18:51:17
 Re: Super 88 manifolds in reply to A.P., 05-14-2005 18:32:33
The stud spacing is 3 3/8 or 3 1/2. the listings for new manifolds list 2 or 3 different ones. Will any of them mount to the exhaust ok.
A.P.
05-15-2005 03:02:21
 Re: Super 88 manifolds in reply to Douglas Jones, 05-14-2005 18:51:17
Any of the replacement manifold sources that I am aware of only list one exhaust manifold, which is good for the whole range of models (88, Super 88, 880, 1600 and 1650 with gas engines). The same replacement manifold sources list two intake manifolds; one for the 88 & Super 88 gas models with the small carb mounting spacing and the other with the large spacing carb mounting flange for the 880, 1600 & 1650.
Originally there may have been more variations available from Oliver or White and still may be through AGCO. What is the source of the manifolds or part numbers that you are looking at? I do not see a reason why the exhaust manifold and the correct one of the two intake manifolds will not work.
