S55 Odd rattling noise from rear - Ideas?
KM
05-13-2005 07:03:51
When I have have a load on the three point like a mower, box blade something heavy and when I turn sharp I hear a rattling like a stong vibrating coming from the rear of the tractor. Does not need to be hooked up to the pto. Don't feel it or anything and no noticable performance issues and only does it on sharp turns while in the turn when you straighten her out no noise. Thanks
KM
05-13-2005 13:00:45
 Re: S55 Odd rattling noise from rear - Ideas? in reply to KM, 05-13-2005 07:03:51
Only makes it on the ground and does not make a difference on which way I turn.
J. Schwiebert
05-14-2005 08:45:25
 Re: S55 Odd rattling noise from rear - Ideas? in reply to KM, 05-13-2005 13:00:45
How frequent is the noise. The only thing that moves when you turn and does not move when you go straight is in the differential. If you want piece of mind I guess for no more work that it is take the hydraulic unit off and look at the pinon gears and side gears.
J. Schwiebert
05-13-2005 12:48:53
Make any difference which way you turn. Are you turning with the brakes or without the brakes>
How about if you jack one wheel up and let the other one down to you here it then?
