2255 starter
lucky1468
05-09-2005 20:18:22
Will the starter come out with jacking up the engine
Jim Meade
05-11-2005 07:15:22
 Re: 2255 starter in reply to lucky1468, 05-09-2005 20:18:22
Yes, but it helps to lubricate it with a few cuss words.
2255TR
05-10-2005 09:30:58
The proper way to remove the starter is to first remove the right exhaust manifold.exhaust down pipe and the alternator . Then tie a rope through starter solenoid and slide the starter forward through engine tub and out beside radiator.I would highly recommend against lifting the front of this engine up more than about 2 inches. The reason is that the over/under hydraul shift actually slips inside the input shaft of the transmission and is sealed with an o-ring. If you lift to much they have been known to break the end of the input shaft.
charley c
05-10-2005 04:53:01
i had a 1974 2255 with a 3150 and it would, tight fit
