660 manifolds, carb aircleaner
RickB
05-08-2005 13:04:44
The 660 uses a larger intake that has a larger flange to fit the larger TSX775 carb. The exhaust manifold has a rear discharge (common to the 550) with a separate part (only used on the 660) to adapt the muffler to the manifold. This separate exhaust pipe bolts to the manifold with a two bolt flange, and is braced to the manifolds at the center with a 'T' shaped piece of flat stock. The air cleaner discharges to the carb at an angle via a rubber hose with another 45 degree angle in it. The 66/S66 air cleaner discharges horizontally into the smaller carb via a straight hose.
