880 front axle
pj
05-06-2005 12:38:02
I have looked at a couple pictures on the net today.
After seeing these pictures I think the 880 I bought has a different looking axle.
Did they have different axles standard or adjustable.
It might be the same as the pics. Thanks in advance
Jim Meade
05-07-2005 04:57:20
 Re: 880 front axle in reply to pj, 05-06-2005 12:38:02
In the narrow front end you had the row crop double tire and the single tire.
In the wide front you had the RC adjustable wide front, the industrial and the wheatland. There were also after-market RC wide fronts you see from time to time.
The RC had large rear wheels and the others had smaller rear wheels. The RC will look like a pipe with a wishbone. Pull a pin and slide parts of the pipe in or out to adjust the width. Industrial and wheatland are not adjustable, except for swapping the tires around, I think.
pj
05-07-2005 07:03:16
 Re: 880 front axle in reply to Jim Meade, 05-07-2005 04:57:20
Thank you for the info. I am going to try and get it home today.
I am sure there will be more Questions to come.Thanks again
