OK Im Confused(3pt hitch) 1650
SJ
05-05-2005 15:59:18
OK I have never used the 3pt on my 1650 yet.I bought a cheapo post hole digger(Lienbach Line).Now I havent tried to hook it up yet,was just looking over how it could be hooked up.First off I have no idea how to hook up the end of the post hole digger to the top link,they just dont match up like my little Ford 600 did. Now what I do have is a extra part that came with my 5ft Kingcutter brush hog,it is a U-shaped piece of steel with 2 different sized holes in it and a bushing going through the larger hole,something tells me this is an adapter to hook up to cat-2 3pt.Is this correct(please say yes)? Also it seems that my lower arms on 3pt should raise higher to accomadate a post hole digger for transporting,using etc.Is there an adjustment for this? Has someone set the lift range for a certain implement so they can just move control back and forth and have proper heighth.I found an adjustment screw with a lock nut hooked up to the 3pt control lever,will this change heighth range? Any other pointers will be welcome.
Thanks
Stan
SJ
05-07-2005 04:39:48
 Re: OK Im Confused(3pt hitch) 1650 in reply to SJ, 05-05-2005 15:59:18
Sorry thats a 1550.
