880 OLIVER CARB FREEZING
Brent Oberdieck
09-01-1999 08:42:49
HOW DOES ONE KEEP THE CARB FROM FREEZING ON THE 880?
LynMn
09-04-1999 12:19:25
 Re: 880 OLIVER CARB FREEZING in reply to Brent Oberdieck, 09-01-1999 08:42:49
Thermostat ok? Air cleaner restricted? this will cause frosting.Hot spot on manfold working? there should not be a block off plate at joint between intake and exhaust manifold.Correct carb? I dont know what weather condtions you are operating in. If all fails. Pre-heat air with metal flex tubeing from top of aircleaner to muffler area Oliver used this idea on some 1600 tractors it may cut power.This info is for gas not L.P.
