Needed: Oliver Mechanic RE:770 Power Booster
Dan Johnson
08-31-1999 17:34:32
Fellas, Here is my problem: My 770 will work with the power booster in low range but if you put much fuel to it the power boost jumps into neutral. If you are in high and pull it into low it will go but still jumps into neutral often. My question is, do I go ahead and pull the engine and get to the power booster or am I missing an easier way. Thanks, Dan
LynMn
09-04-1999 09:02:44
 Re: Needed: Oliver Mechanic RE:770 Power Booster in reply to Dan Johnson, 08-31-1999 17:34:32
There is no neutral in P.B. tran. Check sprag clutch (one way) and related parts in P.B.Use shop manual. Line up housing correctly. This is important. Use proper light weight oil. I dont think an oil change will help you now.You will need alot of high priced parts. This unit can be removed and replaced with 77 parts
